1. esued's Avatar
    Hello:
    So I joined the beta program after around the nougat release just to check the changes before the OTA; after that I've been having some batery problems. The phone sometimes shuts down at around 20-40%, when I tried to power it up, I get an empty batery icon, but when i plug the phone an turn it on, it shows around the level that it shuted down. I don't see bumps on the back of the phone that could indicate a faulty batery, also when I put the phone on bootload it says that the batery is okay. Any way of fixing this? or should I go back to marshmallow?
    09-19-2016 09:39 PM
  2. ebrandwein's Avatar
    My battery life under 7 was terrible. Rolled it back to 6.01. Certainly helped.
    09-19-2016 10:35 PM
  1. Battery issues
    By Jcblack3310 in forum Honor 8
    Last Post: 09-30-2016, 01:40 PM
  2. Major SD problem.
    By Nuuq in forum LG G3
    Last Post: 09-21-2016, 01:40 AM
  3. Is my Note 7 about to go boom? :) Check out these battery stats..
    By slopokdave in forum Samsung Galaxy Note 7
    Last Post: 09-20-2016, 12:12 PM
  4. Replies: 1
    Last Post: 09-20-2016, 12:13 AM
  5. Do the note 7 and the s7 edge use the same battery?
    Last Post: 09-19-2016, 08:00 PM
