    Hello,
    I did a factory reset on my Nexus 6 and during the process it suddenly turned off. I wasn't able to turn it on and when it finally did it went into AP Fastboot Flash Mode.
    I was trying to start the system but it didn't work. It just shows goes into Google screen for a split second and then goes back to the AP Fastboot Flash Mode. I tried all the settings in there, i.e. Recovery, Factory Reset but the result is the same.
    Any idea how I can make this work again?
    Thanks for all the help.
    12-24-2018 01:12 PM
  2. Rukbat's Avatar
    Connect the phone to a computer with fastboot installed (ADB and fastboot - installing and using) and type
    fastboot reboot
    If it still reboots to fastboot, you'll have to install the ROM - it's gone. See Google | Factory Images for Nexus and Pixel Devices.
    12-25-2018 04:20 PM
  1. Verizon Galaxy S8 Trouble setting default SMS messaging app on Samsung Galaxy S8 for use with Google Voice
    By alf_dart in forum Samsung Galaxy S8 & S8+
    Last Post: 12-27-2018, 01:57 PM
  2. OK Google no longer works while listening to music on my
    Last Post: 12-27-2018, 05:23 AM
  3. Is anyone using the LG G6 on Google Fi?
    By patruns in forum LG G6
    Last Post: 12-26-2018, 09:31 AM
  4. Replies: 2
    Last Post: 12-25-2018, 07:33 AM
  5. OK Google no longer works while listening to music on my
    Last Post: 12-24-2018, 08:41 AM
