I tried to install Nexus 7 Smoothrom but once it got to the stage where you needed to boot to recovery and select partitions it wouldn't do it whatever I tried. Eventually after trying many things to get into recovery I decided just to re-install the factory OS using the same toolkit Nexus 7 toolkit for bootloader unlock, rooting, custom recovery, etc.
The process downloaded and wiped my nexus OK then proceeded to install the factory OS with all reports coming back OK. However once it had to reboot at the end the nexus just shut off and will not come back on. I've tried holding down the power button and power+down but it's just dead!
At this stage does anyone have any ideas?
