Save big + get 3 months free! Sign up for ExpressVPN today
  1. SuperDarkKnight's Avatar
    About a month ago I got a nexus 7 tablet ( 16 GB wifi) via a promotion from att but recently i've noticed that the battery life doesn't seem to be what it used to be. Could anyone tell me if I'm getting normal battery life or am I just being paranoid.
    Attached Thumbnails Normal nexus 7 battery life?-screenshot_2013-06-29-04-25-15.png   Normal nexus 7 battery life?-screenshot_2013-06-29-04-24-59.png
    06-29-2013 04:27 AM
  2. Aquila's Avatar
    It doesn't seem to be too far from normal and nothing showing really outstanding on the stats side of it, but it's hard to tell in so short of a time. You're basically losing 10-12% per hour with the screen on, which is 8-10 hours of screen time if it's consistent. You may save a little more by turning auto-brightness off (if it's on) and/or turning brightness down a little. It does seem a little strange that it wasn't awake for the majority of the time... were you using it or was it sitting there with the screen stuck on?
    2defmouze likes this.
    06-29-2013 04:33 AM
  3. SuperDarkKnight's Avatar
    The brightness is usually turned down to about 15% if that, I was using my nexus the time that it was awake.
    Aquila likes this.
    06-29-2013 01:09 PM
  4. Paul627g's Avatar
    Also what is your setting time for how long the screen stays on when idle? I think the stock setting is 2 minutes. I usually bump all my devices down to 30 seconds. That extra screen time sitting on especially on higher brightness settings can gobble down battery.
    SuperDarkKnight likes this.
    06-30-2013 09:19 AM
  5. SuperDarkKnight's Avatar
    It's set to 30 seconds. This is what a days usage looks like. Screen obviously taking up most of the battery.
    Attached Thumbnails Normal nexus 7 battery life?-screenshot_2013-06-30-22-46-13.png   Normal nexus 7 battery life?-screenshot_2013-06-30-22-45-57.png   Normal nexus 7 battery life?-screenshot_2013-06-30-22-46-23.png
    06-30-2013 10:51 PM
  6. petergoogle's Avatar
    You should really go by "screen-on time" as it is the main drain source.
    I get about 5 hours on mine.
    07-04-2013 06:58 PM
  7. UberWhomp's Avatar
    I've gotten up to 7-8 days on mine. With average use per day..
    Mostly playing emulators, facebook. tumblr, remote desktop, browsing the web and drawing in Sketchbook....
    I'll see if I can post a screen shot
    07-30-2013 11:05 AM
  1. Nexus 4 doesn't seem to like headphones!! :-/
    By Pradeep Rajendran in forum Google Nexus 4
    Last Post: 01-12-2014, 07:20 AM
  2. Ridiculous battery drain this morning
    By Beth Ohrt in forum General Help and How To
    Last Post: 06-30-2013, 01:46 AM
  3. Replies: 0
    Last Post: 06-29-2013, 03:09 AM
  4. Is 68% Battery drainage from screen normal?
    By ohsnapsitsLE in forum Samsung Galaxy S4
    Last Post: 06-28-2013, 06:28 PM
