    I am looking to install Kali Nethunter on my old Nexus 7 2013. I want to start a career in pentesting and it was just lying around so why not?
    First I unlocked by doing "fastboot oem unlock", then installed TWRP using "fastboot flash recovery twrp.img". This step put me into a bootloop of TWRP crashing, but I was able to fix this using "fastboot -w" which wipes user data. This was recommended on a forum.
    Now I can access TWRP recovery mode, but I'm stuck in a bootloop whenever I try to boot into Android. I have used "adb sideload" to reload stock device image from google but I'm still stuck in an endless boot loop. I have tried three different versions and it still doesn't work. I even tried installing Magisk since I heard that can help fix broken files, but I get an error when I try to do that. If my Nexus is bricked I can accept that, but if anyone has a suggestion that will fix it that would be awesome!
    03-26-2022 10:42 AM
  2. B. Diddy's Avatar
    Welcome to Android Central! I moved this to the Nexus 7 (2013) Rooting/ROMs/Hacks forum for more specific traffic.
    Please register on this forum, which will allow you to engage in discussion more easily, as well as post images. https://forums.androidcentral.com/as...community.html
    03-26-2022 12:04 PM
  1. 5 apps in homescreen dock on Oneplus 8pro with only 4 in a line above??
    Last Post: 03-26-2022, 12:22 PM
  2. What does a black circle on the left hand side of my oppo reno 5 means?
    Last Post: 03-26-2022, 12:18 PM
  3. How to delete outlook.com incorrect contact on Android
    Last Post: 03-26-2022, 12:12 PM
  4. Stop notification popups on galaxy a52
    By Jons22s in forum Android Apps
    Last Post: 03-26-2022, 10:27 AM
  5. Replies: 1
    Last Post: 03-25-2022, 11:55 AM
