1. cooljeff913's Avatar
    I was able to root my device, and install android 9, but when I tried to install the pico gaps for it, I received a message that I did not have enough storage available.
    Is there any way to further reduce the storage requirements?
    12-02-2019 07:03 PM
  2. cooljeff913's Avatar
    Unlocked device, rooted and installed android pie. I have 16gb storage available on the device. tried to install GAPPS for pie and received error not enough storage available.
    12-02-2019 07:09 PM
  3. belodion's Avatar
    Threads merged.
    12-02-2019 07:16 PM
  4. hallux's Avatar
    16 available or 16 total? 16 total might make it a squeeze. If installing Gapps is the first thing you're doing I'm leaning to the 16 total as the increments would have 8, 16, 32.
    12-02-2019 08:20 PM
  5. B. Diddy's Avatar
    I moved this to the Nexus 7 (2013) Rooting/ROMs forum for more specific traffic.
    12-02-2019 10:05 PM
  6. cooljeff913's Avatar
    I just tried this again on a new nexus 7 2013 with 32gb.
    get the same error.
    after installing rom for android pie, system partition shows only 60mb free.
    don't get it! I have twice as much storage available, but it does not work
    12-06-2019 12:42 PM
  7. mustang7757's Avatar
    get the same error.
    Possible something wrong with that ROM you installed, have you contacted the developer of it ?
    12-06-2019 12:49 PM
  1. Pictures taken with your 7.1
    By kbz1960 in forum Nokia 7.1
    Last Post: 05-06-2020, 11:24 PM
  2. Galaxy Note 10+ charging specifications confusion. Need help.
    By hy_tek in forum Samsung Galaxy Note 10 & Note 10+ (2019)
    Last Post: 12-03-2019, 06:03 PM
  3. How to bring back deleted Chrome icon. Help please.
    By Cynthiadin in forum Ask a Question
    Last Post: 12-02-2019, 10:24 PM
  4. Need help installing android 9 on nexus 7 2013 w/16b
    By cooljeff913 in forum Ask a Question
    Last Post: 12-02-2019, 07:03 PM
  5. Tempered Glass for Cover Display
    By monty Stinson in forum Samsung Galaxy Fold
    Last Post: 12-02-2019, 03:06 PM
