When I began having problem with charging a battery in my Nexus 7, I found that many other people are having the same trouble but very few who managed to solve that. Assuming that charging problem may have different sources, it looks like majority of them may come from one main source. In my case problem was in a battery movement inside a battery compartment and that movement has made a battery connector separated. That separation did not happen to be a complete, but loosen enough to bring all kind of charging troubles. Prevention of the battery movement with solution of your choice will resolve a problem.
As it was mentioned in post # 6 here: http://forums.androidcentral.com/google-nexus-7-tablet-2012/270069-nexus-7-wont-charge.html , you may open the cover yourself.
Hope that may be helpful.
