1. AC Question's Avatar
    this microprint is about 1 inch wide and 2 inches high. It has about 8 to 10 lines
    05-03-2015 09:08 PM
  2. B. Diddy's Avatar
    Welcome to Android Central! Microprint? Do you mean there is some small text there? Does it constantly change as you're using your tablet? You probably have a Developer Option turned on. Go to Settings>Developer Options, and see if you have some of the monitoring options turned on.
    05-04-2015 01:30 AM
  1. Should I upgrade to Lollipop on my SG S4 i9505 yes or no?
    By AC Question in forum Samsung Galaxy S4
    Last Post: 05-25-2015, 06:22 AM
  2. Cant respond to sms
    By pharmnatr in forum LG Watch Urbane
    Last Post: 05-09-2015, 02:49 PM
  3. girls are the worst / vzw sux
    By coloneljames in forum Samsung Galaxy S6
    Last Post: 05-05-2015, 05:20 PM
  4. Why won't my Samsung S6 connect to AT&T wifi?
    By pemone in forum Samsung Galaxy S6
    Last Post: 05-04-2015, 09:20 PM
  5. Replies: 1
    Last Post: 05-03-2015, 10:06 PM
