1. AC Question's Avatar
    The connection between my charger & nexus 7 has suddenly become loose and it will not charge unless I hold it securely in place. Can this be fixed?
    06-09-2015 02:35 PM
  2. B. Diddy's Avatar
    Welcome to Android Central! Is the connection like that with any microUSB cable? If so, then it's the port that's damaged, and would need to be replaced. But if another cable stays in snugly, then just use that one.
    If you have the 2013 Nexus 7, you could also use wireless charging.
  3. B. Diddy's Avatar
    systemofadown1 likes this.
    06-09-2015 04:16 PM
  4. johnbradley79's Avatar
    I've had the same problem. Only with me it was the charger's jack that was faulty. It's a good thing that all the devices at home are Samsungs and use the same micro USB cables. So with another cable - the problem is no more.
    I'd suggest you first try with another cable. If it works....
    06-10-2015 03:47 PM
  1. Privacy Protection code locks me out. No sultion.
    By Bertold Berenyi in forum Android Security Apps, Tips & Strategies
    Last Post: 06-15-2015, 12:38 PM
  2. Black/Red Theme- No Root Required
    By f308gt4 in forum Samsung Galaxy S6
    Last Post: 06-13-2015, 02:30 PM
  3. Replies: 1
    Last Post: 06-12-2015, 08:25 AM
  4. Need car charger that can handle 2 Droid Turbos
    By TurboCommander in forum Motorola Droid Turbo
    Last Post: 06-09-2015, 09:44 PM
  5. Why I am not able to migrate the data to Google Nexus 6?
    By AC Question in forum Google Nexus 6
    Last Post: 06-09-2015, 10:58 AM
