1. theTHRILL01's Avatar
    My battery has been giving me problems for a while now. Fast battery drain, even when in sleep mode, even when charged in. I've tried everything possible on every forum on the internet, it seems. I decided to do a factory reset and flashed CM12.1. I haven't connected to Wi-Fi, downloaded ANY apps, and I've even left it on Airplane mode. The following is the battery drain that I'm getting now in sleep mode with NO use.
    Is there anyone who can help me? This is ridiculous.
    08-02-2015 06:47 AM
  2. Crashdamage's Avatar
    What happens if you load a stock ROM? Or ASOP?
    08-02-2015 07:22 AM
  3. theTHRILL01's Avatar
    Same issue.
    08-02-2015 08:01 AM
  4. Crashdamage's Avatar
    Very strange. I have a feeling this might be hardware. Possibly a bad battery, but that's just a hunch.
    08-02-2015 08:15 AM
  5. theTHRILL01's Avatar
    I've replaced the battery. Same issue.
    08-02-2015 08:42 AM
  6. theTHRILL01's Avatar
    This is a screenshot from BetterBatteryStats. I have no idea what to make of this info, but might something having to do with *alarm* be causing the problem?
    08-03-2015 07:33 PM
  1. Replies: 42
    Last Post: 08-12-2015, 03:43 PM
  2. s6 edge battery power pack
    By Tahertboy in forum Samsung Galaxy S6 edge
    Last Post: 08-10-2015, 01:39 AM
  3. Gear 2 battery
    By cachun402 in forum Samsung Gear 2 & Gear 2 Neo
    Last Post: 08-02-2015, 09:51 PM
  4. Replies: 4
    Last Post: 08-02-2015, 08:11 AM
  5. Replies: 1
    Last Post: 08-02-2015, 07:25 AM
