Re: GPS Problems on Nexus 7 (2013)
I cannot get the GPS to work on my Nexus 7 (2013).
Sometimes it'll work for 10 minutes, and then just gets stuck in 1 spot.
This is using my tether from Galaxy S6.
Anyone know where the GPS sensor / connectors are located inside? I have found zero teardowns that point this out.
Anyone think a Hard Reset might be worth a shot?
Originally Posted by
RobotTimes This is using my tether from Galaxy S6.
I didn't read through it, but if it isn't here then it's probably not out there.
When you say that you're tethered to your S6, do you mean for a data connection? If you disconnect that does the GPS work properly? (You can use something like GPS Test https://play.google.com/store/apps/d...tcross.gpstest to find out.)
I think it's unlikely that a Factory Reset would fix the problem, but what do you have to lose?
