1. motorcycle_monkey's Avatar
    I just noticed yesterday that when I lower the volume to off, then click up to the first audible volume, there is a noticeable hissing sound above the audio. This happens for the first two clicks of sound, then the sound becomes louder. I turned it up to mid-level and put in my ear-buds and couldn't hear the sound. Not sure if it's just me or not. This happens with or without headphones plugged in. I just past my 14 day return period with Staples, so I may be stuck sending it back to ASUS, unless another retailer would swap for me. I was on a cruise for a week during the initial return period, so lost a week of "normal" use. Thanks ahead of time to all that reply!
    Cheers!
    08-16-2013 08:46 AM
  2. motorcycle_monkey's Avatar
    Surely I'm not the only one having this issue...
    08-17-2013 02:39 PM
  3. jerrykur's Avatar
    I just tried this and could not reproduce the issue. But I have a bit of tinnitus (ringing in the ears) from years of motorcycle riding and racing
    08-17-2013 02:46 PM
  4. franko515's Avatar
    Yes I get the same thing. In not sure if it's a hardware problem or software problem. I don't want to return mine as that is the only thing wrong I noticed. Not even sure if this would be a problem going forward, but yes I also have this issue.
    I posted about it here
    http://forums.androidcentral.com/sho...d.php?t=300637
    Sent from my Nexus 7
    08-17-2013 05:47 PM
  5. motorcycle_monkey's Avatar
    I agree Franko515. I have had pretty good luck with my devices, original N7 and now this one, so I don't want to chance getting another one that my have other issues. Cheers!
    08-19-2013 10:51 AM
  6. markdek's Avatar
    Ah, what sad times these are when we consumers are afraid to get more defects in replacement hardware....
    08-19-2013 11:10 AM
  7. Citizen Coyote's Avatar
    Cheers!
    Nope, not just you. Mine does this as well at times, although for me it's only noticeable on some apps and then only when I'm in a very quiet location. As you describe it goes away when the volume reaches a certain level or with using headphones. It bothered me for the first day or two but now I don't really notice it.
    08-19-2013 02:35 PM
  8. HalizDad's Avatar
    Hmmm...I'll vote for software being the culprit as poweramp doesn't do it, but Google player does...on mine...
    Sent from my Nexus 7 using AC Forums mobile app
    08-19-2013 04:22 PM
  9. franko515's Avatar
    For the posters that also had this problem. Does anyone hear the same whine from the top speaker with brightness set below 35% while using auto brightness? If so I had the same problem but after I stopped using auto brightness the sound is gone now (least I hope it has). Maybe the screen just had to warm up or something.
    08-19-2013 06:42 PM
  10. Citizen Coyote's Avatar
    Not that I've noticed.
    08-20-2013 10:45 AM
  11. donqui's Avatar
    I got the same problem and returned it to the shop...waiting for the replacement ! In the meantime I have tried in a shop to set through google music play and "desactivate" the surround sound...seems the hissing sound is less present...I will confirm once I will get the nexus back ;-)
    11-19-2013 08:19 AM
  1. Not able to download from Google Playstore on Vodafone 3G
    By Rajiv Mohan Gandhi in forum Samsung Galaxy Note 2
    Last Post: 11-29-2013, 06:15 AM
  2. any way to mimic bottom 3 buttons on screen?
    By pjoseph in forum Samsung Galaxy S4
    Last Post: 09-09-2013, 04:45 PM
  3. [SOLVED (SORTA)] Tab won't turn on or charge (Or charges extremely slowly)
    By frostilicus in forum Samsung Galaxy Tab 2 10.1
    Last Post: 08-16-2013, 04:28 PM
  4. I ONLY get 4G on my Atrix HD using Simple Mobile
    By tll1975 in forum General Help and How To
    Last Post: 08-16-2013, 12:24 AM
  5. Wi Fi won't turn on
    By diogotinoco in forum General Help and How To
    Last Post: 08-15-2013, 11:30 PM
