1. preppystud's Avatar
    so it seems that this new 7 has some gps problems. does every tablet have the same problem, or it happens to some users, what is the percentage?
    and can this be fixed with a software update in the future?
    08-22-2013 04:04 PM
  2. rxnelson's Avatar
    It is pretty bad if you need it for a while. However they are releasing a patch that supposedly addresses GPS and multitouch.
    https://productforums.google.com/for...1-875-false%5D
    Sent from my Nexus 7 using Tapatalk 4
    08-22-2013 05:51 PM
  3. YAYTech's Avatar
    With the supposed fix just released and still rolling out via OTA updates, I would say either
    a) Go ahead & pick up the new N7 if the GPS issue was the only thing holding you back, and just be prepared to return it if the update doesn't actually fix the issue (assuming it's a deal-breaker for you)
    or
    b) Wait several days to hear reports back from folks about whether it seems to truly fix the issue.
    Honestly, I bet it will fix the issue, and this few weeks of hiccups will become a blip in our rear view. That tends to be the case with many issues that come up in new versions of Android. Everyone makes a big stink for a few weeks, it's fixed, we all move on.
    08-22-2013 06:04 PM
  4. Daniel62's Avatar
    When are these updates sent out? I just checked mine and it says I am up to date. My Build says JSS15J
    can you go to a website and get it somehow?
    thanks
    08-22-2013 07:11 PM
  5. YAYTech's Avatar
    thanks
    Generally OTA (over-the-air) updates roll out over the course of 2-4 days, or you can force it following instructions here: http://forums.androidcentral.com/goo...need-wait.html
    08-22-2013 08:06 PM
  6. preppystud's Avatar
    so did the new update fix the problem now?
    08-24-2013 07:01 PM
  7. PablofromCA's Avatar
    Yes everything works perfect no touch screen lag and the gps works fine
    08-24-2013 07:05 PM
  1. Replies: 121
    Last Post: 09-06-2013, 09:55 AM
  2. How is the Reception?
    By TBoltJ in forum Verizon HTC One
    Last Post: 08-25-2013, 08:41 PM
  3. Auto-update apps turned off and that is the way I want it!
    By patruns in forum Google Play Store
    Last Post: 08-24-2013, 03:24 PM
  4. Problem with whatapps
    By sharon low1 in forum General Help and How To
    Last Post: 08-23-2013, 07:48 AM
  5. Is there any way of getting back on Verizon's unlimited data plan.
    By nightstalker581988 in forum General Carrier Discussion
    Last Post: 08-22-2013, 06:47 PM
