So I have had mine for about 10 days and overall very happy with it.
The battery life however is bugging me, I am used to my iPad Air which gets an easy 15-16 hours of usage and 3+ days of stand by.
I am not exactly sure how to compare but if I take the screen on time of the Nexus it is around 8 hours and total off the charger time almost two days. The iPad battery is much higher capacity but that should be offset by the bigger screen.
What type of battery life do most of you get and any particular app/s that you find to be the culprit. Here are the battery stats, can someone tell me what can be improved?
Thanks much.
Sent from my Nexus 7
Thanks much.
