1. prof_rosewood's Avatar
    I use my Nexus 7 with an aviation app. I have a dry cell 12v battery that I plug the Nexus into but the main battery still drains. Any ideas on why or other ways to add an aux battery?
    09-06-2014 06:55 PM
  2. GSDer's Avatar
    Welcome to the forums!
    Am I missing something about your setup? None of these devices use 12V - they're all expecting 5V, and some current load from 500 mAh to 2A. And even that doesn't guarantee that the charge will keep up with the discharge rate - it's pretty common for a device running a CPU/graphics intensive application to continue to discharge (albeit at a slower rate) while connected to a power source.
    Sent from my rooted, debloated, deodexed Sinclair ZX-80 running CM -0.001 using Tapatalk
    09-07-2014 12:40 AM
  3. prof_rosewood's Avatar
    I am sorry for omitting the fact that I attached a cigarette adapter then plugged in a usb adapter that outputs 5v. It doesn't keep up with the drain. The battery is a 12v 7amp hr.
    09-07-2014 12:19 PM
  4. GSDer's Avatar
    Ok. You'd have to look at the output rating for the USB adapter that you're using - it could be anywhere from 500 mAh to 1A. Even at 1A there may not be enough juice to keep the tablet from discharging.
    Do you have the GPS turned on?
    Is Wi-Fi on?
    Is the screen brightness at full?
    09-07-2014 07:16 PM
  5. cab2's Avatar
    09-09-2014 01:05 PM
  1. Why is my battery TERRIBLE!?
    By Unregistered in forum Ask a Question
    Last Post: 09-11-2014, 06:46 AM
  2. My tablet is gone beyond a doubt.
    By Carlos Palomo in forum Ask a Question
    Last Post: 09-07-2014, 04:48 AM
  3. My photo in default messaging app
    By Patrick Arial in forum Samsung Galaxy S5
    Last Post: 09-07-2014, 04:43 AM
  4. Is it donezo? Droid wont stop cycling on and off
    Last Post: 09-07-2014, 12:00 AM
  5. FREE BEER (seriously) to anyone who can unbrick my phone!
    By MaskdBagel in forum HTC One Rooting, ROMs & Hacks
    Last Post: 09-06-2014, 08:59 PM
