1. DudeItsSheen's Avatar
    Hello guys! I've received my shiny new nexus 7 2013 yesterday but I've noticed that my battery life is quite bad... I don't know if it's because of the device or is it because i recently updated to lollipop. I've heard that people are having problems with their battery when they updated to lollipop. So i don't know if it is just my OCD or my tablet has a really suckish battery life
    Ps: i get around 6 hours on a straight, light to moderate use, wifi is always turned on, I've decreased the brightness (i would say that im in 10%), I've tried every battery saving technique but still... I get 6 hrs. I posted a screenshot of my battery stats hope that helps.
    Thank you for responding!!
    Attached Thumbnails Nexus 7 2013 (Battery Issue) on lollipop-screenshot_2015-04-01-17-31-00.jpg
    04-02-2015 12:47 AM
  2. itguyjax8430's Avatar
    Did you buy in brand new from the store? Did you get the update and then updated it when you powered it on?
    04-02-2015 09:13 AM
  3. DudeItsSheen's Avatar
    Yes it is brand new then I updated it to 5.0, i got the update when I powered on the device.
    04-02-2015 09:53 AM
  4. itguyjax8430's Avatar
    I would try doing a factory reset of the device. For some reason there has been a lot of problems with the updates on a lot of phones and tablets. Doing a factory reset generally fixes most issues.
    04-02-2015 10:12 AM
  5. DudeItsSheen's Avatar
    Oh ****? Is it that bad? I mean i haven't installed a lot of apps since I had it. Would a reset be necessary?
    04-02-2015 10:41 AM
  6. itguyjax8430's Avatar
    If you just got it and haven't put a lot of stuff on it, it shouldn't be that bad. You can just download it all again and be good to go.
    04-02-2015 10:44 AM
  7. DudeItsSheen's Avatar
    Well okay i'll just notify you if you're still online. Hey man thanks for helping a brotha out in advance. But I'm still wondering how would i know if the battery is now okay?
    04-02-2015 10:46 AM
  8. itguyjax8430's Avatar
    You hopefully will start seeing better battery life because the OS will be operating correctly.
    04-02-2015 10:49 AM
  9. RattleSnake506's Avatar
    Thank you guys for posting this. I've had a similar problem from a while on 5.02. I even reset the device once after updating. Even though I keep "WiFi off when sleeping" setting on, it still continues to drain the battery and the major culprit is either Google play services or android OS. I don't know what I can do. I've turned off all possible syncs off. I hope 5.1 fixes this drain
    Sent from my Nexus 7 using Tapatalk
    04-15-2015 09:38 PM
  1. music player crashing after updating to Lollipop 5.0
    By Nick2point0 in forum Samsung Galaxy S5
    Last Post: 11-26-2015, 12:38 AM
  2. How do I disable the update notification of Lollipop?
    By AC Question in forum Android 5.0 Lollipop
    Last Post: 11-03-2015, 04:22 AM
  3. How can I get my data to work on my S4 on Consumer cellular?
    By AC Question in forum Samsung Galaxy S4
    Last Post: 04-02-2015, 08:46 AM
  4. How to Get Audible Caller ID on the HTC M9?
    Last Post: 04-02-2015, 08:38 AM
  5. How I can setup debug mode on Android device?
    By Claude Speed in forum Ask a Question
    Last Post: 04-02-2015, 05:10 AM
