1. AC Question's Avatar
    I bought my Nexus 7 in January 2013. The codes are
    1B015A
    CBOKBC750010
    I need to know because the charging port has failed and all the wireless chargers I need to use to get round this refer to Nexus 7 2013.
    Can someone clever help me discover if it is Qi enabled please?
    05-17-2017 11:00 AM
  2. B. Diddy's Avatar
    Welcome to Android Central! The easiest way to tell if you have a 2012 or 2013 Nexus 7 is if it has a front-facing camera. The 2013 version has one, while the 2012 doesn't.
    The 2013 version does have wireless charging, but the 2012 does not.
    On the other hand, the 2012 version has a pogo plug (look for contacts along the side of the unit) which are used for the dock. These can be used for charging as well. https://www.amazon.com/Nexus-7-2012-...cUvbUpU5818550
    GSDer likes this.
    05-17-2017 12:37 PM
  1. Replies: 1
    Last Post: 05-17-2017, 12:56 PM
  2. Replies: 1
    Last Post: 05-17-2017, 12:50 PM
  3. How eo i remove this unwanted ad?
    Last Post: 05-17-2017, 12:41 PM
  4. Where can I find out how many minutes I have in this phone?
    Last Post: 05-17-2017, 10:01 AM
  5. Why does my auto rotate not work?
    Last Post: 05-17-2017, 09:41 AM
