1. robjordan's Avatar
    Nexus 7 (2013) battery has frequent episodes where it sounds an audible low battery alert. Looking at the battery usage chart, the battery level has dropped almost to zero. But then it recovers back to the previous level. Sometimes, if the 'battery low' period is a little longer, the tablet will turn off. I have replaced the battery, but this did not alter the behaviour. I suspect something wrong in the battery management circuitry. I don't mind disassembling and replacing parts, but at present I have no idea what component is likely to be at fault.
    Battery level dives almost to zero intermittently, then (mostly) recovers-3392154854256531237.png
    01-02-2019 10:35 AM
  2. Rukbat's Avatar
    That looks like a dendrite (Lithium Battery Dendrite links). The battery has to be replaced. It's nothing you did (or can do about) as you'l see if you read some of the links.
    01-02-2019 12:26 PM
  3. robjordan's Avatar
    Thanks, but I replaced the battery and still have the same problem.
    01-02-2019 12:46 PM
  1. Why did the minimum media sound level increase after update?
    By Android Central Question in forum Moto G5 & G5 Plus
    Last Post: 01-07-2019, 08:56 PM
  2. ZeroLemon Pixel 3 XL 4700mAh Slim Power Battery Case
    By bkrickles in forum Pixel 3 Accessories
    Last Post: 01-03-2019, 04:57 PM
  3. I have a swipe to unlock AFTER pattern unlock
    Last Post: 01-02-2019, 03:06 PM
  4. Why am I losing connection to mobile network
    Last Post: 01-02-2019, 02:55 PM
  5. S8 Battery Drain Faster
    Last Post: 01-02-2019, 01:05 PM
