AppsolutelyMAD
It's almost certainly a problem with the update itself and not the hardware. To be perfectly honest with you I wouldn't recommend flashing the factory image when you have the options of waiting for a fix or getting a replacement, but the option is there for those that are impatient, but I don't think anybody would want to brick a Nexus 9 even if the chances are small. Anyway I hope your problem is resolved soon and you get a chance to appreciate your new device.
