09-17-2015 02:24 AM
91 123 ...
tools
  1. Paul627g's Avatar
    Since people are starting to get these in their hands I'm sure there will be some things to talk about. Found a bug, problem, gremlin or have a fix? This is the place to talk about it.
    UJ95x likes this.
    11-04-2014 03:25 PM
  2. ckeathley's Avatar
    I'll move it here but is seems like my wifi is kind of wonky. Lots of network errors. Can't even complete a speed test. Anybody else get this?
    traut5 likes this.
    11-04-2014 03:34 PM
  3. quadtronix's Avatar
    No WiFi issues yet... Only been using it a few hours though.
    Paul627g likes this.
    11-04-2014 05:16 PM
  4. jspring86's Avatar
    My wi-fi has been good, but as many have said the battery life is not so great and it takes forever to charge fully. Also, several of my go-to productivity apps won't even open, mainly Moon Reader Pro which I use for PDF work.
    11-04-2014 05:45 PM
  5. gtt1's Avatar
    I use cool reader as my ereader and it doesn't remember where I left in fact it doesn't remember what book I was reading. Worked fine with kit kat. Hate to lose that app as it is full of great features.
    Google reader works fine but am not that familiar with it. I like to just sideload books into a books directory and load from there but I guess with Google reader you have to upload them to use them.
    namlunoy and Paul627g like this.
    11-04-2014 06:37 PM
  6. Paul627g's Avatar
    Again I think were looking at some devs that need to update their apps. This always happens with every major OS update. Shame too because Google did remind the developer community to get their apps updated with the new API's and such in preparation for Android 5.0
    namlunoy likes this.
    11-04-2014 06:59 PM
  7. jsabo's Avatar
    Marvel Unlimited crashes during their fancy startup-screen every time so far. Annoying, as that's been my most-used app recently.
    11-04-2014 08:20 PM
  8. Mooem's Avatar
    So I think I have pretty significant light bleed going on. I'm not sure if its just my unit or if its par for the course with anyone else.
    Anyone else have it this bad? I'm thinking about getting an exchange if this is out of the norm.
    I have the 32 GB White from the Play Store.
    11-04-2014 08:47 PM
  9. flattie's Avatar
    One small bug I've noticed on mine:
    Google Play Music is unable to play any of my music when accessed via the Play widget (the album art one which collates all your Play Store content).
    I have to force close the app from the settings menu to regain control over my music.
    Other widgets and accessing via the app icon cause no issue.
    11-05-2014 07:38 AM
  10. Sammy_C's Avatar
    The Sky Go Tablet App says that it won't work properly with 5.0 but you can sign up for a Beta test. As already mentioned its a case of developers getting their apps/games updates (also seen of FF1 that they need to update and are working on it so pretty common at the moment).
    Battery wise not far enough in but I'd recommend a full charge then a full discharge on all new Nexus 9's before testing battery life.
    Gets fairly warm playing Hail to the King: Deathbat but nothing out of the ordinary, still more than comfortable.
    Basically nothing major yet, great tablet!
    11-05-2014 08:00 AM
  11. gtt1's Avatar
    Not getting notifications for Yahoo mail but it does download my mail. Checked and notification settings are okay.
    11-05-2014 09:53 AM
  12. Rastor's Avatar
    I am having some app compatibility issues. Gangstar Rio and GTA Vice City won't play at all. Has anyone tried one of those on their Nexus 9 and can confirm they aren't working?
    11-05-2014 12:21 PM
  13. FormerTexan's Avatar
    I must have gotten a DOA unit, mine is stuck on "Downloading Update" and I haven't been able to get past this screen. Took it into Best Buy and they couldn't even get it to connect to their network (one of the geeks said it's a known prob with Lollipop). They finially found a network it would connect to and it wouldn't download there either. I can arrow back to the previous screen but it just sits on the "Downloading Update" screen for hours doing nothing. I guess it's going to stay at Best Buy....
    11-05-2014 06:55 PM
  14. brandonr416's Avatar
    OK Can someone please help me make sense of all this. This tablet is not working at all. Its very laggy, I try to open youtube and it takes about 4-5 seconds to respond? How is is possible with a processor this big ? Also for widgets with live moving tiles they just freeze? Also wifi issues, drops, battery drains very slow. charges take at least 7 hours.
    Apps issues? Show box doesn't work . screen mirror cast to choromecast doesnt work. XMBC players doesnt work, can't install flash adobe plugin for fire fox beta. I miss my N7 and I am ready to return this thing... Please HELP or am I doing something wrong ?????
    11-05-2014 07:36 PM
  15. xDonJuanx's Avatar
    Former Texas :Mine took about an hour to download; even though the screen said 5 minutes
    Posted from my Nexus 7
    11-05-2014 09:18 PM
  16. flippedout's Avatar
    The one issue I have experience so far is Wi-Fi drops. Oddly though this only happens at work. Home has been rock solid (knocks on wood).
    An interesting note: while the OS is super fast and smooth, I have noticed many of the Google apps are choppy. Guess they have some tweaking to do because this tablet should be able to handle anything thrown at it.
    11-05-2014 09:41 PM
  17. FormerTexan's Avatar
    Any amimations on the screen while downloading? Any arrows up down on the Wifi symbol? Anything? Mine just sits there with nothing moving, no indication it's doing anyting... I've waited hours... thanks for the post!
    11-05-2014 10:08 PM
  18. Rastor's Avatar
    Arrows for data transmit/receive are gone in 5.0 Lollipop.
    My memory is that there was a bar that filled for downloading the update, but for me the process went quickly -- so quickly I don't really remember.
    11-06-2014 08:17 AM
  19. pfunnyjoy's Avatar
    I saw a very thin yellow progress bar when downloading the update. But set against the white and light blue, not terribly noticeable. Thought at the time they could have made it a bit more obvious, someone with vision issues could easily have missed it.
    I did see a bit of lag on mine when it went into battery saver mode last night, but not before. Otherwise very smooth and fast so far.
    Sent from my Nexus 10 using Tapatalk
    11-06-2014 02:21 PM
  20. Matt Sherman's Avatar
    I have been having a lot of WiFi issues on mine. It will occasionally loose WiFi connection when I'm sitting in my room. I have all kinds of other devices in my room that don't loose connection. As soon as I walk towards my router it picks up the signal. The router is standard issue relatively new by my local ISP. Have you figured anything out about this?
    11-06-2014 03:07 PM
  21. Pedro Prats's Avatar
    So far i've found 2 apps crashing as i try to open them up: Any.Do and MEO Music.
    11-06-2014 06:32 PM
  22. Savvas Eracleous's Avatar
    I have exactly the same problem as FormerTexan and i cant any solution..
    11-06-2014 09:52 PM
  23. maxburn's Avatar
    I'm seeing a TON of software issues, I actually wish I could downgrade to 4.4.4 if such a thing were possible. I know it's early adopter and all but it's not a finished product. I love the hardware though, zero issues with that it's a great tablet so it has a lot of potential IMO. That's about the only thing keeping me from returning it actually.
    Such a stark contrast from my new Xperia Z3 compact which just seems that everything works great. I'm actually noticing a bunch of things working better than they ever did on my nexus 5, it's a genuine pleasure in the software experience.
    One of my worst gripes about the nexus 9 isn't googles fault though, it seems that the Amazon Instant Video app doesn't support tablets which was a surprise to me as it works on nexus 7. As crappy a reason that is it might be the thing that makes me return the nexus 9, I seriously want AIV on my tablet.
    11-07-2014 07:27 AM
  24. NicksGarage's Avatar
    So far only a couple apps I use don't work.
    Also the "ok Google anywhere", face unlock and NFC unlock don't work.
    Sent from my HTC One M8 via Tapatalk 4 Pro
    11-07-2014 11:42 AM
  25. D Mac's Avatar
    My Multitasking button keeps stopping working.
    A least once a day it just completely stops working. When I hit the on screen button it lights up to show it's been pressed but the multitasking list doesn't come up. I tried manually killing all the running apps but it still doesn't work. The only fix is a reboot. ... Until the glitch comes back and I have to reboot again
    Anyone else have this issue? Anyone have a fix for it?
    11-08-2014 12:26 AM
91 123 ...
  1. Nexus 9 WIFI issues?
    By Clifton Keathley in forum Google Nexus 9
    Last Post: 11-10-2014, 03:24 PM
  2. Replies: 1
    Last Post: 11-09-2014, 08:17 PM
  3. Replies: 1
    Last Post: 11-05-2014, 02:23 AM
  4. Replies: 1
    Last Post: 11-05-2014, 02:22 AM
  5. Why am I having issues connect my phone to my car?
    Last Post: 11-04-2014, 02:47 PM
Tags for this Thread
