1. ezzzzz's Avatar
    so I have noticed that at work I get no idle drain on WiFi, but at home I do. maybe like 2-3% per hour. any thoughts???
    Posted via my Nexus 9
    12-22-2014 02:08 PM
  2. srkmagnus's Avatar
    Are you sure its related to WiFi? Could it possibly be related to a poor cellular signal at home, rather than at work?
    ezzzzz likes this.
    12-22-2014 07:43 PM
  3. LinuxWeather's Avatar
    Do you have a 5GHz band at home enabled as well? Perhaps your swapping between bands for best signal strength? Are there more than one network at home or that you can connect to? Its most likely some signal issue, I'd check the networks at home, forget all but the one you use, disable multiple bands in advanced WiFi settings, and make sure signal is strong. You can always also set WiFi to off when sleeping to save battery.
    ezzzzz likes this.
    12-22-2014 07:52 PM
  4. ezzzzz's Avatar
    my nexus is pretty stock no crazy apps. just have WiFi version no cell. Its the only thing I can think of
    Posted via the Android Central App with my Moto X G1
    12-22-2014 08:40 PM
  5. ezzzzz's Avatar
    home WiFi is just standard, not 5. and just one network. will disable multiband thou just in case
    will let u know
    12-22-2014 08:42 PM
  6. ezzzzz's Avatar
    so feel stupid posting this but I have to let the people know! thanks all for racking ur brain,the culprit was location on/off. with off zero battery drain.
    update: I lied, wasn't location. don't know what I did, I turned off tablet, charged over nite, cleared cache. I got no noticeable standby battery drain and I'm at 13 percent and screen time is over 5 hours. Previously I have only about 4 hours max so I'm not sure what's going on but I guess it's okay
    matt3166 likes this.
    12-23-2014 06:30 AM
  7. LinuxWeather's Avatar
    Hey at least its resolved, that's the important part.
    12-24-2014 08:23 PM
  1. Replies: 5
    Last Post: 01-29-2015, 11:51 AM
  2. Note 4 not compatible with some apps?
    By enfuego360 in forum Samsung Galaxy Note 4
    Last Post: 12-26-2014, 02:01 AM
  3. Replies: 6
    Last Post: 12-23-2014, 11:31 AM
  4. Google Wallet at Nike
    By TJH132 in forum Android Apps
    Last Post: 12-22-2014, 02:42 PM
