1. VAVA Mk2's Avatar
    Has anyone noticed battery drain issues in the last week or so? Both my Nexus 9 and 6P have been guzzling battery like something is constantly pinging them awake in the background and Doze is not kicking in.
    Posted via my glorious Nexus 6P
    05-30-2016 08:07 PM
  2. H3aTeRzz's Avatar
    Have you recently updated the firmware? If so, you may need to do a wipe of the cache partition, and or a Factory Reset. You can check the recent apps you downloaded, perhaps one of them is causing the issue. You can enter Safe Mode for troubleshooting rogue apps.
    Chris
    05-31-2016 01:45 PM
  3. Zakaria Ouh's Avatar
    i have a nexus 5,and my battery drains either.i did a factory reset and wiped the cash partition,but none of them solved the peoblem.
    i recieve security patch levels every mounth.
    should i do a factory reset every mounth ?
    06-13-2016 01:15 PM
  1. Wi-Fi Scanning turns on by itself, Drains Battery drastically!
    By Jesus Delgadillo in forum Samsung Galaxy Note 5
    Last Post: 02-07-2017, 11:35 AM
  2. Htc Desire 816 Marshmallow Battery Issue
    By wizdom1981 in forum HTC Desire 816
    Last Post: 06-01-2016, 11:01 PM
  3. Replies: 7
    Last Post: 05-31-2016, 11:33 AM
  4. Is my battery dead?
    Last Post: 05-30-2016, 03:34 PM
  5. Is my battery dead?
    Last Post: 05-30-2016, 03:14 PM
