1. Spruce1969's Avatar
    Does anyone know if they can get a replacement remote or what type of AAA batteries does it take?
    02-24-2015 08:11 PM
  2. Rukbat's Avatar
    AAA is the type it takes. The only difference in different kinds of AAA batteries is how long they'll last. Some batteries last longer than others. (I usually use Duracells - I don't work for them, they just seem to be a good price for the quality.)
    Types are AAA, AA, C, D, etc. If it takes AAA, it'll work with any AAA - even if you mix manufacturers. (If you're using rechargeables, don't do that - use batteries from the same lot.)
    02-25-2015 01:02 AM
  3. Spruce1969's Avatar
    I put Raynham alkaline batteries and the light on the top of the remote is flashing and the player doesn't respond to the remote. Any ideas why that is?
    02-25-2015 08:36 AM
  4. Spruce1969's Avatar
    Ray O Vac batteries
    02-25-2015 08:37 AM
  5. scoty024's Avatar
    Sounds like it's no longer paired with the Android TV... our at least needs to be repaired.
    02-28-2015 11:35 PM
  6. mightymikek83's Avatar
    I know this is old but i had to get a new remote. They just me a brand new nexus player.
    I packaged the old one and sent it back. All under warranty. If that light keeps flashing on the remote, just re pair it to the player.
    03-20-2015 03:50 PM
  1. Replies: 14
    Last Post: 03-01-2015, 02:42 PM
  2. How do I add people on a calendar event?
    By MIKA80 in forum Samsung Galaxy S5 Mini
    Last Post: 02-26-2015, 10:18 AM
  3. How do I turn off Google text to speak on my HTC phone?
    Last Post: 02-25-2015, 08:44 AM
  4. My phone is getting hot while in use
    Last Post: 02-25-2015, 01:08 AM
  5. Replies: 0
    Last Post: 02-24-2015, 07:47 PM
