1. ndonnine's Avatar
    Anyone else notice a gap along the entire top screen between the bezel and the glass? I noticed one of my dogs hairs getting stuck in it so I ran the corner of a sticky note in it. There's a gap wide enough for paper all along the top. I could not replicate on the sides.
    Not that this matters because it's almost impossible to see but do you think this will reduce the IP67 rating?
    10-23-2017 08:49 AM
  2. AstroStrat89's Avatar
    Seems like the glass is sitting on top of something that is probably part of the entire back. Maybe the tear-down video you know is coming will show more? I have notices that when looking from the bottom end the glass looks like it's slightly raised on the right side. Like never notice once I get the case on.
    10-23-2017 10:15 AM
  3. ndonnine's Avatar
    Wanna splash yours with water and see if it's still water proof? :P
    10-23-2017 12:43 PM
  4. jlp0209's Avatar
    The screen is glued to the bulk of the phone it seems, someone posted a tear down on this forum earlier today. I can barely get a corner of a fresh piece of paper into a small gap on the bottom of my Pixel 2. Also can do the same on my iPhone 7. I'm not worried about it.
    10-23-2017 10:28 PM
  5. ndonnine's Avatar
    OH mine's bad. I had a dog hair go in between the bezel and the glass and never come back out. I can fit the entire edge of a piece a paper in at least 1 mm and slide it all the way across the top edge.
    10-24-2017 06:26 AM
  1. Subaru & Pixel 2 Bluetooth Issue
    By nitro2k1 in forum Google Pixel 2 & Pixel 2 XL
    Last Post: 04-07-2018, 06:07 AM
  2. Android - Pixel Volume Jumps to Max
    By Android Central Question in forum Google Pixel & Pixel XL
    Last Post: 11-09-2017, 09:09 PM
  3. Questions on pictures taken with and viewed on Pixel 2XL
    By yujinn in forum Google Pixel 2 & Pixel 2 XL
    Last Post: 10-25-2017, 08:47 AM
  4. unlocked bootloader on pixel 2 and 2xl
    By raj gohil in forum Google Pixel 2 & Pixel 2 XL
    Last Post: 10-23-2017, 04:49 PM
  5. Android - Pixel Volume Jumps to Max
    Last Post: 10-23-2017, 06:38 AM
