1. dsignori's Avatar
    When I use Active Edge to open Assistant on my 2 XL , it won't act until I unlock my phone (I use fingerprint locking). It opens and will listen , but won't act until I unlock it.
    Is this normal? Does anyone else who uses fingerprint locking seeing this behavior? It makes it much slower than using other methods if this is the intended behavior.
    10-30-2017 05:10 PM
  2. Ca_lvn's Avatar
    There's a thread that was opened on this a couple hours ago, I tried to link it it was unsuccessful
    Google Assistant auto-unlock with Active Edge?
    10-30-2017 05:15 PM
  3. dsignori's Avatar
    Thanks, Mods, you can close this thread. Sorry I didn't see the other thread on this until now.
    10-30-2017 05:23 PM
  4. Apple2Droid's Avatar
    It might be helpful to rename the other thread so that it's easier to find. If I remember, I think it was just called, "Off Topic."
    11-01-2017 07:22 PM
  5. Pixelfan56's Avatar
    i squeeze and then put fingerprint on immediately, it unlocks instantly and GA asks how she can help
    11-02-2017 08:21 AM
  6. KillerQ's Avatar
    I have face ID on as well, after the squeeze i just look at my phone while talking and it automatically unlocks.
    Pixelfan56 likes this.
    11-02-2017 08:31 AM
  1. Will There Be A Charger Case For The Honor 6x?
    By Android Central Question in forum Honor 6X
    Last Post: 12-17-2017, 08:06 PM
  2. Will There Be A Charger Case For The Honor 6x?
    Last Post: 10-30-2017, 04:48 PM
  3. How to show caller information when receiving an incoming call?
    Last Post: 10-30-2017, 04:14 PM
  4. Replies: 1
    Last Post: 10-30-2017, 03:52 PM
  5. Why my voice is not audible to others
    Last Post: 10-30-2017, 03:50 PM
