- Sep 20, 2012
- 1,567
- 32
- 48
Recently I noticed that Android System shows a notification that Fitbit is using battery. Don't know if this appeared due to a recent Fitbit app update, or the Jan 5, 2018 patch update.
When I check the Fitbit app battery use details, it shows as 0% for the last 24 hours. So, not sure why I was notified.
Thus the following questions:
How do I turn off the persistent notification? I can't seem to swipe it away.
Also, how to configure the battery notification feature so that I am notified if the Fitbit app is using an unexpected or unrealistic amount?
