1. paradroid's Avatar
    Since I got the new Pie update I have made 3 butt dials after not doing a butt dial for years. I think normally to someone I just text or called, embarrassing if it is a client.
    It seems my phone is turning on in my pocket. How do I fix this?
    Also, sometimes when my phone is charging it makes a swishing noise when I pick it up and put it down.
    Also, when I send a message, my phone chimes like when I receive a message. I turned off the setting in messages to make sound on send but is still makes sound.
    I hate Pie. Actually I love Pie, the kind I eat - software, not so much.
    09-03-2018 02:56 PM
  2. cbreze's Avatar
    If it were me I'd just bite the bullet and do a reset back to fresh. To much weirdness going on.
    09-03-2018 03:01 PM
  3. drano's Avatar
    Mine only does it when the phone is hot, as I have found on a long hike 90-100+ deg.
    Pie allows you to lock the phone. Hold the power button and you'll see an option to "lockdown"
    This eliminates any pocket dialing. This forces you to use your 4 dig code to unlcok the phone back to normal use.
    09-03-2018 03:39 PM
  4. TraderGary's Avatar
    I've not had inadvertent dialing since I've made it a habit to tap the ON/OFF button before pocketing. That habit can also save a bit of battery too.
    Blaize19 likes this.
    09-03-2018 03:56 PM
  5. PowrDroid's Avatar
    Yep. I've had this problem for a while now, even before Pie.
    https://r.tapatalk.com/shareLink?url...0&share_type=t
    Although it hasn't done it for a couple of weeks. Maybe because I've been very vigilant about shutting it down, as TraderGary suggests.
    09-03-2018 05:51 PM
  6. Scienceguy Labs's Avatar
    I've experienced this as well. Pulled my phone out of my pocket the other day and I had a screen full of numbers that had been typed into the dialer.
    09-03-2018 08:47 PM
  7. booboolala2000's Avatar
    Mine does not have the same option. Long press of power just gives me restart, off and screenshot.
    Thinking nine must have been the smart Lock feature. Have turned that off for now and will see what happens.
    09-03-2018 09:29 PM
  8. paradroid's Avatar
    Where is the smart lock option in settings? I searched and it does not come up.
    09-04-2018 10:26 AM
  9. paradroid's Avatar
    I believe I turn it off before pocketing, maybe not, but this did not start happening until pie.
    09-04-2018 10:28 AM
  10. Almeuit's Avatar
    No issues here. Phone is always locked before it goes in pocket.
    09-04-2018 03:27 PM
  11. misterdata's Avatar
    I have 2 S9s. Mine hasn't done the butt dial but, since the last software update (2/2019), my wife's fone has been self-dialing a lot. Dialed my fone 5 or 6 times in a row a few minutes apart while the fone was in her purse. Today dialed someone she hasn't called for months while the fone was in the pocket of the treadmill in the gym.
    I've looked for some sort of setting that is different on her fone than on mine and found nothing.
    Both fones have wallet type cases and have not done any butt dialing until this last update.
    02-20-2019 05:41 PM
  1. App to Make a Note and Have it Show Up Somewhere on Phone?
    By Jimmy Bernstein in forum Samsung Gear S2
    Last Post: 09-05-2018, 10:12 PM
  2. Note 9 Sound
    By jnichols16 in forum Samsung Galaxy Note 9
    Last Post: 09-03-2018, 11:13 AM
  3. Replies: 4
    Last Post: 09-03-2018, 10:22 AM
  4. Signal Strength and Battery symbol missing on Staus Bar at top of S9+
    By Android Central Question in forum Samsung Galaxy S9 & S9+
    Last Post: 09-03-2018, 08:18 AM
  5. Signal Strength and Battery symbol missing on Staus Bar at top of S9+
    Last Post: 09-03-2018, 06:34 AM
