Latest chapter of the tale of "Rukbat and the Mysterious Fingerprint Scanner Failure":
After spending almost 4 hours on the phone with Google, ending with the software team (since I have arrived at the conclusion - with which they agree - that there is a massive calamitous [no, I'm trying to keep it way below the actual level of seriousness BUG in Android]). What!?!?!? Yes, a bug in Android. Probably a minor typo that no one noticed, but if you try to add a fingerprint when there aren't any in the database yet, it won't work. It used to. The replacement came with the March patch and it worked. We updated to Pie and it stopped. Wer updated to September and it still doesn't work.
So we did a debug dump on the phone (the "new" [actually refurb] phone that arrived today) and I sent it off to the person who's going to be looking at it, trying to find out why it doesn't work. (And I really do wish him lots of luck - I've been where he is, and he's going to need it.) If he can't find it from a debug dump, the software engineers are going to have to run a phone in full debug - probably a CPU emulator so they can watch, instruction by instruction, what's happening as you try to get the scanner to recognize that you're trying to get to the "scan your fingerprint" screen. Been there too. (Don't ask me why I still have a full head of hair - that's one mystery I've never solved - I should have torn it all out, clump by clump, after almost 60 years of debugging things that don't work just due to IPIO - the Innate Perversity of Inanimate Objects.)
At least I now know why the trouble exists, and where it exists - and I fully understand that it could take them 6 months to find the bad code. I'll wait. (Maybe I'll send Sandar a bill for debugging services. After all, I figured it out all by my little old self. [Well, 5'9" old self.]) But it will probably be found, and fixed, and included in an update. Maybe not October, maybe not November, but it's being worked on, and that's all I can ask for.
(And someone "up there" now knows that the Pixel 2 (and, I'm betting, the Pixel 3 - and the XL versions of both) aren't compatible with flashing using a USB 3.0 port and a USB 3.0 cable. They weren't aware of that until today. It's only been all over XDA since about last year. Maybe they'll give me a job forwarding legitimate problems like that to them.)
Oh, and please do not delete your fingerprints and try to add them back. It may work. Or you may be left with a phone that doesn't do fingerprint scanning. I've warned you, so don't complain to me.
09-07-2018 07:20 PM
