11-22-2018 08:49 PM
67 123
tools
  1. mustang7757's Avatar
    11-10-2018 11:56 PM
  2. chezm's Avatar
    Wish dark mode changed more areas such as settings, got my set to dark mode and it's great
    mustang7757, Coop61 and Morty2264 like this.
    11-11-2018 12:00 AM
  3. mustang7757's Avatar
    Google should allow this through the UI
    xzell and Coop61 like this.
    11-11-2018 12:05 AM
  4. L0n3N1nja's Avatar
    I miss the old days when Android was dark by default, before material design made everything bright and white.
    mustang7757 and Coop61 like this.
    11-11-2018 12:18 AM
  5. mustang7757's Avatar
    Or at least have the option
    11-11-2018 12:31 AM
  6. chezm's Avatar
    Agreed, not sure why they're pushing white... especially if dark saves battery wouldn't it by default make more sense to extend battery life?
    mustang7757 likes this.
    11-11-2018 12:33 AM
  7. mustang7757's Avatar
    Guess it was that material design they were looking for but realized it's not good for battery
    11-11-2018 12:36 AM
  8. Mike Dee's Avatar
    Well they made a lot of dark changes since last year. By the way the Android Central app has a dark mode.
    dtresca likes this.
    11-11-2018 01:03 AM
  9. mustang7757's Avatar
    Yeah they headed in right direction, message app ,phone app soon and able to do notification ,app draw,Google feed
    11-11-2018 01:09 AM
  10. akhil8's Avatar
    Yes dark mode must be an option, it will really helps the phone having amoled or oled displays
    11-11-2018 05:53 AM
  11. cactuspete23's Avatar
    Its like turning off lights when you leave a room! Great idea
    anon(10274434) likes this.
    11-11-2018 07:13 AM
  12. Kayza's Avatar
    Because material design tends to look a lot nicer. And they were designing for LCD where it didn't really matter in terms of battery life.
    11-11-2018 07:16 PM
  13. EMGSM's Avatar
    Been using Dark Mode for a while and I've noticed a difference in regards to battery life.
    11-12-2018 02:15 AM
  14. TraderGary's Avatar
    Here's another article talking about battery life and dark mode. I'm impressed with the statistics in the article. Fortunately I prefer dark mode and select it whenever possible.
    https://www.theverge.com/2018/11/8/1...d-battery-life
    Coop61 likes this.
    11-12-2018 03:00 AM
  15. I Can Be Your Hero's Avatar
    Everyone was saying this when Material Design was revealed and had everything white. That was a big criticism that I remember of MD.
    Finally they are doing something about it.
    11-12-2018 03:37 AM
  16. zrajm's Avatar
    From a UI perspective, using a bright background cuts down on the (perceived) reflections on the screen, and is therefore beneficial for the users in a brightly lit environment. It also increases the readability of text. I bet this is why we see lots of apps and computer interfaces with bright backgrounds. : )
    P.S. The above doesn't mean that I like it. I think it's annoying as hell (I wish there was a decent way to make my browser dark).
    chezm likes this.
    11-12-2018 09:01 AM
  17. Kayza's Avatar
    Both of these things are real issues. If you're doing a lot of reading on your phone, night mode could be headache inducing.
    anon(10092459) likes this.
    11-12-2018 08:46 PM
  18. Dean Liensdorf's Avatar
    IMO dark mode should be the default so that we get the best battery life from the get go.
    11-12-2018 09:14 PM
  19. DeannaM9's Avatar
    I agree with you.
    11-12-2018 11:42 PM
  20. Tom Gautot's Avatar
    I think it's a good thing that they said it as it will "force" us developers to make dark themes. And I am a fan of those.
    11-13-2018 12:47 PM
  21. mustang7757's Avatar
    And now in November update if you put battery saver on it defaults to dark theme
    11-13-2018 01:01 PM
  22. Mike Dee's Avatar
    No way!
    11-13-2018 03:01 PM
  23. mustang7757's Avatar
    11-13-2018 03:21 PM
  24. Theot's Avatar
    One of the things I liked about Samsung and LG is the ability to theme easily.
    I still find it laughable that they just figured this out.
    11-13-2018 06:27 PM
  25. mustang7757's Avatar
    They had it early on in Nexus builds
    11-13-2018 06:38 PM
67 123
  1. What Color Profile are you using?
    By DarkNeo in forum Google Pixel 3 & Pixel 3 XL
    Last Post: 11-19-2018, 02:38 AM
  2. Battery life stuck. Won't go up or down
    Last Post: 11-11-2018, 07:11 PM
  3. Can i buy overseas phone and use in Australia
    Last Post: 11-11-2018, 03:28 AM
  4. How to improve battery life on s9 pus?
    By Dwang3633 in forum General Help and How To
    Last Post: 11-11-2018, 03:24 AM
  5. Why my phone battery drains quickly and the screen gets heat up tremendously.
    Last Post: 11-10-2018, 10:38 PM
