Twice yesterday my Pixel 3 XL 128GB was unable to change focus on the rear camera. Very blurry image. (I took several photos, but trashed them or I would post example.)
Reading it appears to be the Laser Distance Sensor is not functioning. I took off the clear plastic case, cleaned the area around the sensor, and restarted the phone. After doing this multiple times, it seemed to come back. But same problem resurfaced a couple of hours later. No amount of cleaning the area, or leaving the case off completely could restore it.
https://play.google.com/store/apps/details?id=com.mobiledirection.proximitysensorreset installed. I ran that, (though it is really designed to work on only the front proximity sensor) rebooted and it seems to have cleared it up, at least temporarily. This leads me to believe it is a setting, cache, whatever, not a hardware or lens-covered issue.
Anybody else?
Anybody else?
