Yesterday evening I noticed battery level had dropped to 35% around 1800. I didn't think too much about it as I got caught up in dinner and then Netflix. Had the intention to take a look at battery utilization, but by the time I looked again at 2200, phone had shut down. Battery level dropped to 0% (could only see that after connecting to wired USB C charger once the phone powered back up).
I'm working from home and on WiFi all day along with strong Verizon signal. The only things I used the Pixel 3 for yesterday were light texting, checking email, and about 55 minutes as a hotspot while out during lunchtime workout. When I got home after the workout, battery level was around 75%. So, something decided to grab CPU cycles afterward.
I was planning to investigate before bedtime, but was not able to check due to the phone shutting down (caught up in Netflix and forgot to look). So, is there an app I can install that can go back and show historical battery utilization details? I've used GSam Battery Monitor Pro in the past, but after Android 10 - I think - root access was required to get details, so I uninstalled the app. Or is there a way to check historical battery utilization details using the built-in Battery settings and its features? The May system/security update is installed, while the Google Play Services is still on the March update.
