1. RC51 RIDER's Avatar
    I have a pixel 3aXL and was wondering if anyone in counted this , I have it plugged in to the correct fast charging plug and cord and I'm loseing battery percentage when I'm on Facebook , Instagram and streaming music !
    10-04-2019 08:59 PM
  2. B. Diddy's Avatar
    Are you plugged into a wall outlet or a powerbank? If it's a powerbank, are you sure the input you're using on the powerbank is output, and not input? Some powerbanks use the USB-C port only for charging input, so you might be using the phone to charge the powerbank.
    Sorry, as I looked this over, I realized that when you said "fast charging plug," you meant the wall plug, correct? Does the lightning bolt show up in the battery icon at all?
    10-04-2019 10:59 PM
  3. kmcochran's Avatar
    I have noticed that when I'm fast charging in my car and using navigation, sometimes the battery percentage doesn't increase very fast, especially if my battery is at 20% or so. Try turning your screen off to see if it says "Fast Charging" at the bottom.
    10-05-2019 10:34 AM
  1. Battery replacement
    By mark7914 in forum Samsung Galaxy S8 & S8+
    Last Post: Today, 01:31 PM
  2. Charging Buds with 25W brick
    By nubold in forum Samsung Galaxy Note 10 & Note 10+ (2019)
    Last Post: 10-04-2019, 09:01 AM
  3. Why is my battery charging itself?
    Last Post: 10-03-2019, 04:23 PM
  4. Note 10 + battery drain concern
    By Lecrae116 in forum Samsung Galaxy Note 10 & Note 10+ (2019)
    Last Post: 10-03-2019, 12:59 PM
  5. Note 10 + battery drain concern
    By Lecrae116 in forum Samsung Galaxy S10 & S10+
    Last Post: 10-03-2019, 11:51 AM
