1. PaulQ's Avatar
    Let me preface this by saying my car's manual doesn't address this. (obviously?)
    My new car has a wireless charging pad in the center console. This is also the location where you plug in the cable for Android Auto. That cable charges the phone too. The natural place to put the phone when plugged in is on the wireless pad.
    Doing the math - a possible scenario is that it can be plugged into a power source AND be on a live charging pad.
    At least once, I saw the wireless light turned on while my phone was sitting there. Maybe a fluke. From then on, I turned off the wireless charger.
    Before I "play around" to see if it consistently and continuously disables the pad on its own when plugged in, do any of you know if the phone itself has a protocol for when this scenario happens? Or - does it just charge faster?
    Thanks!
    01-15-2020 11:36 PM
  2. Rukbat's Avatar
    Whether the receiver in the phone is drawing power from the pad or not (that's what turns the light on), if the phone is plugged in, it's not charging from the pad. It's an either-or circuit.
    milehigherik likes this.
    01-16-2020 03:38 PM
  3. PaulQ's Avatar
    First, I am inclined to go with what you (Rukbat) say here.
    But, for the record, I actually recalled there was Pixel "support" this morning and decided to chat with them about this issue (before I saw your post here). Unsurprisingly, it was a strained conversation. The transcript below starts after I had already explained the question once. This starts with me rephrasing the question.
    Paul
    If I plug my phone in, it sits on top of the wireless charging pad. So - it is plugged into the car with a cable AND sitting on the wireless charging pad that is on.
    Paul
    Is that going to damage my phone?
    Harry
    Paul, I would like to inform you that while the device is connected to 2 different charging source so it might damage the device, as we never recommend it.
    Harry
    This could affect the battery.
    Paul
    So the phone has nothing to prevent it. It just starts charging from both sources?
    Harry
    Yes. we can not disable any one of them, as it is made on the mechanism that is we will put the device on charging pad, it will charge.
    Paul
    I'm not sure I understand. What does the phone do when it's on a charging pad and plugged in at the same time?
    Harry
    Paul, it will usually charge. However the excess amount of power could affect the battery.
    Paul
    Ok, so it does charge from both sources at the same time? I want to be sure I understand so if I talk to my car manufacturer I can tell them what the phone does.
    Paul
    It does not cut off either source, right?
    Harry
    Yes, that is correct!
    So, I don't think I got an informed answer to my question. Not helpful. I think the "either-or" explanation makes sense.
    01-16-2020 10:34 PM
  4. Mike Dee's Avatar
    I believe the wired circuit takes priority when plugged in and disables the charging coil
    01-21-2020 07:15 PM
  1. Downloaded documents (PDF, Word, etc) not showing up in My Files (Galaxy S8)
    Last Post: 01-22-2020, 01:01 PM
  2. Get rid of Finder Search in favorite tray?
    Last Post: 01-21-2020, 10:54 PM
  3. how can I turn my smartphone into a dumb phone
    Last Post: 01-21-2020, 10:36 PM
  4. Watch is taking calls when my phone is plugged into Android Auto
    By marker227 in forum Samsung Galaxy Watch Active 2
    Last Post: 01-16-2020, 08:47 PM
  5. Stuck in kid's mode due to son entering password wrong too many times
    Last Post: 01-15-2020, 08:59 AM
