1. sitnaing83's Avatar
    I am on Vodafone with P6 Pro. Having issue with call not received and straight away show missed calls on 4G and 5G.
    I can receive calls on 3G.
    Fixes done as follows:
    - The sim disconnect and reconnect by technical team to refresh sim. Issue still persists.
    -Reset network on phone. Issue still there.
    - The customer officer adviced for New SIM swapped at shop on same day.
    Issues still persist and not sure whether it is due to setting on phone.
    Flip to Shh is off also.
    Has anyone seen and solved this issue before please?
    11-02-2021 04:15 PM
  2. B. Diddy's Avatar
    Did you get the phone from Vodafone, or from somewhere else? Which country are you in? I wonder if the Pixel 6 Pro still doesn't support VoLTE in some countries: https://piunikaweb.com/2021/10/21/go...ian-countries/
    11-03-2021 12:13 AM
  3. sitnaing83's Avatar
    I got it from Vodafone UK. I guess 4G and 5G would be supported here in Pixel series.
    11-03-2021 01:34 AM
  4. B. Diddy's Avatar
    Does this also happen in Safe Mode? https://support.google.com/pixelphon.../2852139?hl=en
    sitnaing83 likes this.
    11-03-2021 10:06 AM
  5. sitnaing83's Avatar
    Thanks a mill, Diddy.
    On safe mode, it works on any network for call receiving.
    Upon restart, home launcher bring back pixel launcher. Now I rerun my Hyperion launcher and it still works for call receiving.
    One complication might be phone app too.
    I was previously on Beta for call screening. I reverted back by leaving beta program before safe mode.
    B. Diddy likes this.
    11-03-2021 12:01 PM
  6. B. Diddy's Avatar
    Ok, so all good now? If the problem comes back, try uninstalling Hyperion for a few days and see if that solves it.
    11-03-2021 05:09 PM
  1. Play Store review not showing as published
    By chawke in forum Google Play Store
    Last Post: 11-04-2021, 10:35 PM
  2. Replies: 3
    Last Post: 11-03-2021, 09:10 AM
  3. Doro phone on android pie
    Last Post: 11-03-2021, 12:37 AM
  4. My pixel 6 is brown on apps not red?
    By Android Central Question in forum Google Pixel 6 & Pixel 6 Pro
    Last Post: 11-03-2021, 12:32 AM
  5. My pixel 6 is brown on apps not red?
    Last Post: 11-02-2021, 02:27 PM
