Originally Posted by
B. Diddy I can't say I know all of the details of how AccuBattery works, but that section specifies "Foreground app battery usage," so it doesn't necessarily include how much battery apps use in the background. Granted, in my system settings Battery menu, my apps have minimal background usage, but it might still contribute.
Now I see the header that says "Foreground..." Missed that. There's another tab for "Discharging speed" and Tile isn't on the list.
B. Diddy From the stats you list, it does seem that Tile is using quite a bit of battery. It's worth uninstalling it temporarily and seeing how things go. I also wonder about the Headphones app and the Orbi app. Are they necessary, or do they just add a little more functionality?
I don't think either is absolutely necessary but I would lose control of the headphones and router. I could uninstall but only temporarily.
I want to get a clean overnight reading, starting at 100% tonight. See what happens.
B. Diddy In the system settings Battery menu, also scroll down to the System Usage for Past 24 Hr and tap that -- what are the percentages there?
Mobile Network Standby 8%
Ambient Display 7%
Screen 6%
Phone idle 4%
Android OS (greyed out 3%)
Android System (greyed out 2%)
WiFi 2%
Thanks for exploring this - Always learning.
