How do I transfer files directly from Pixel 7 Pro to a flash drive?
Nov 22, 2022
13
Do you see any option to allow USB storage access in Files by Google, as mentioned in the link I previously shared?
Hi B Diddy. I never received a request for permission to access in Google files. However, when I open files, the flash drive appears in the storage section and I can access the files on it. I just can't copy anything to the drive
Nov 22, 2022
13
These are my relevant screens. As can be seen, the flash drive is recognized in Google files. The second screenshot shows how after I select and then choose either "move to" or "copy to" only internal storage is an option.
BTW, I have tried several flash drive with the same result
B. Diddy
Senior Ambassador
Moderator
Mar 9, 2012
165,581
4,711
113
Have you tried a 3rd party file manager yet, like Total Commander?
Are you able to move a file from the USB drive to​ Internal Storage?
mustang7757
Super Moderator
Moderator
Feb 6, 2017
91,560
6,135
113
dc52ltr
928
45
28
If you press on the 3 horizontal lines on the top left of your screenshot, does it not give you access to the USB storage/internal storage and you can copy files from there..? I'm sure that's how I did it...
Sent from my Pixel 7 Pro using AC Forums mobile app
Nov 22, 2022
13
Unfortunately not. When I press the 3 dots I can choose to move or copy a file but the flash drive is not included as a destination option - only internal storage
crossfade_93
Hi! A bit late to the party, but I recently got an M.2 USB case to convert an old ssd into a USB drive. When trying it out on my pixel 7 Pro I ran into the same issue as you, where the Google files app detects the drive, but does not allow me to write to it. I tried total commander and it allows me to write to the USB drive, but I still prefer the simple interface of the Google files app.
Looking around a bit more inside the Google files app I actually found a way to write to the USB drive from the phone's internal storage, by going down to:
Storage devices -> Internal Storage -> selecting folder and file(s) of choice -> click the three dots -> copy or move -> two options now show up, internal storage and the name of my USB drive!
So it seems to be a bug of the Google files app, where you cannot copy to a USB drive in any other way than by clicking your entire way through the file tree of your internal storage to your desired files.
Hope this helps someone!
/Oscar
bnutz
