Hello,
Got my Pixel today however I am wondering if there is an issue with my volume rocker. The "volume up" click has a much more hollow sound to it, and the button behaves as if it's 2-stage. If I push it slowly, it depresses slightly, as if it has travel before it comes into contact with the actual part of the phone that registers the press. It feels as though it's supposed to be attached directly to something under it, but isn't. Pressing it further and you get the full, click you would expect. The "volume down" does not exhibit this behavior. It's not a huge deal, I just want to make sure mine isn't defective. Can anyone else please check if there's is like that? Is there a significantly different pitch "click" sound comparing volume up to volume down?
Thanks very much.
Thanks very much.
