1. babouc's Avatar
    I have a Pioneer AVIC-8200 which worked flawlessly with my iPhone. After having owned an iPhone since they came out, I took the plunge on a Google Pixel and now I cannot get Android auto to function. I tried two different cables, updated the firmware, launched Android Auto from the phone, etc. NOTHING!
    I emailed Pioneer but (of course) no response and have given up on trying to call them (hung up after 31 minutes wait).
    Anyone has any suggestions? This is incredibly frustrating!
    Thanks!
    10-28-2016 09:15 PM
  2. bespinct's Avatar
    Not that it helps you now, but send a big report to Google too. It's possible there's a unique issue in the Android Auto software with that device.
    10-28-2016 09:29 PM
  3. babouc's Avatar
    Thanks. I emailed the Android team 3 days ago and no response either!
    10-28-2016 09:45 PM
  4. babouc's Avatar
    Just to qualify, I did get an answer but just the canned: "Check out our help forum", etc.
    10-28-2016 10:02 PM
  5. Cant Miss's Avatar
    Same problem with my avh4100nex.
    babouc likes this.
    10-29-2016 08:32 AM
  6. 4onthefloor's Avatar
    Anyone find a solution? My Pixel XL and AVIC-8200NEX combo won't allow me to get past this screen:
    Pixel + Pioneer AVIC-8200NEX = incompatible? Android Auto problem?-drutpt1.jpg
    11-23-2016 06:39 PM
  7. babouc's Avatar
    Still nothing. I keep calling Google and Pioneer but getting the same BS "we're working on it". Considering that I spent close to $2K between the AVIC-8200 and Pixel phone, I would expect that it would work... Super irritating...
    11-23-2016 08:54 PM
  8. babouc's Avatar
    Latest update. Pioneer is supposedly going to put out an update in... February next year. Totally ridiculous but at least it seems that they are addressing the issue.
    12-07-2016 08:47 PM
  9. gearloos's Avatar
    Just FYI this is still an issue. I have the latest firmware (1.04) on my 8200nex and a Pixel XL with current updates and get the exact same red screen. Followed Pioneers workaround by turning off AVICSync etc.. tried Pioneers suggested cables, ordered 3 on the list from Amazon, oh well needed some USB-C cables anyway. Worked great with Apple car play. Just hate Apple telling me what to do so went back to Android. I see that was a mistake. From what I've read, Android Auto is a complete mess.
    08-04-2017 03:42 PM
  10. easyrotor's Avatar
    Also FYI, I have a AVH-4200NEX (V1.6) and a Pixel running 8.0. Android Auto works perfect until the HU warms up for an hour or two and then it will crash, reset, and crash again until USB is disconnected. Obviously a bad HU but now I own a lot USB C cables I did not really need. Guess that old saying about how everything looks like a nail if the only tool you have is a hammer comes to mind. Love the setup when it works.
    09-20-2017 03:18 AM
  11. Aragorn1469's Avatar
    Mine only works in USB2 slot. Try changing your cord, just remember that firmware can only be updated in USB1.
    As for the e brake, the green cable must be attached to you e-brake sensor to ground it out when e-brake engaged. You can also ground it to the black ground wire on your wiring harness.
    10-11-2017 10:29 PM
  1. Fluidity of the pixel?
    By alex217c in forum Google Pixel & Pixel XL
    Last Post: 11-10-2016, 09:25 PM
  2. Google Pixel XL or LG V20?
    By JoshDunc in forum Google Pixel & Pixel XL
    Last Post: 11-03-2016, 05:24 PM
  3. Replies: 19
    Last Post: 10-29-2016, 01:00 PM
  4. Google Pixel XL or LG V20?
    By JoshDunc in forum LG V20
    Last Post: 10-28-2016, 10:39 PM
  5. Best Android Phone Under $700
    By Mike Dee1 in forum LG V20
    Last Post: 10-28-2016, 08:42 PM
