    Hello
    I have some weird issue which i already reported to google but still not resolve. When i attached any wireless headphone to my headset which is Google Pixel with Android 8.1.0 and January Security patch update 5th Jan 2018, and then if any incoming call, it will not wake up and screen showing black as idel mode. Even phone is ringing in both headset and also device. Then if i click power button it will show who is calling. Does anyone facing same issue. Please let me know if any one got any resolution. Performed most of the step suggested by Google team.
    01-08-2018 12:13 AM
  2. B. Diddy's Avatar
    Welcome to Android Central! Does the screen wake up properly if the headphones aren't connected?
    01-08-2018 11:47 AM
  3. Bucsfan76's Avatar
    I also have the same issue. Works fine when Bluetooth headset is turned off
    01-08-2018 09:54 PM
  4. brodrick's Avatar
    Mine too. If I have my bluetooth headset on, my phone stays black when a call comes in. I have to hit the power button to wake the screen to see who's calling.
    01-10-2018 02:32 PM
  5. B. Diddy's Avatar
    It might be intentional. The rationale could be that if people have a Bluetooth device connected (for calls), the phone is often in one's pocket. If the screen turns on while the phone is in the pocket, it may increase the chance for unintentional screen touches. I'm not aware of a way to change how that behaves, though.
    01-10-2018 03:21 PM
  6. hallux's Avatar
    Same issue I'm having. In the thread I started, we discovered that if I removed the updates to the phone app it works correctly.
    https://forums.androidcentral.com/go...ml#post6132960
    B. Diddy likes this.
    01-13-2018 09:40 PM
  1. Sound on text does not work
    Last Post: 01-08-2018, 11:53 AM
  2. Can we solve the ic issue of Android phone? And if yes then how it will be?
    Last Post: 01-08-2018, 11:51 AM
  3. sd card not working
    By Ali Jahangir in forum Ask a Question
    Last Post: 01-08-2018, 11:49 AM
  4. A circle with a cell phone what does it mean
    Last Post: 01-08-2018, 11:48 AM
  5. Replies: 1
    Last Post: 01-08-2018, 04:48 AM
