1. Dan L2's Avatar
    Not sure if this has been posted (search doesn't work well from the app)
    But I found that turning off Adaptive Battery (Android Pie) has significantly improved battery life. Now with screen off the battery isn't dropping and screen on is way way better.
    The difference is night and day.
    09-23-2018 10:36 AM
  2. Kirstein Gourlay's Avatar
    Not tried it yet but that is very interesting
    09-23-2018 10:38 AM
  3. Chuckcell's Avatar
    Hmm, found it and turned it off. However ... the description reads as if Adaptive Battery ON is supposed to result in a longer period between charges.
    09-23-2018 11:45 AM
  4. Dan L2's Avatar
    Battery is definitely lasting longer with adaptive battery turned off.
    09-23-2018 01:48 PM
  5. J Dubbs's Avatar
    I factory reset my pixel after upgrading to Pie and all the settings are bone stock and I can't kill my battery in a normal day..... and I've tried lol. And the battery doesn't drop at all in standby mode. I'm not running any third party apps though, that would probably make a difference.
    Have you tried a factory reset? I know it can be a pain if your phones more customized, but I see so many folks fighting constant irritating problems that a factory reset would most likely fix. I always factory reset after an os upgrade, and I've been fortunate enough to never have any real issues to speak of ;-)
    09-24-2018 04:16 AM
  6. ylap's Avatar
    Bought my Pixel XL a week ago, with 8.1 on board. Received update to 9.0 and one bug fix update as soon as turned it on. Installed all my apps after both updates, so everything works fine without a factory reset. No battery drain. Quite happy with it as for now.
    10-01-2018 02:56 AM
  7. dyastrab's Avatar
    I have a weird battery problem since installing PIE. My Pixel XL still discharges even when the phone is completely shut down (15-18 % overnight). I'm going to try turning of adaptive battery to see if that helps.
    10-07-2018 11:11 AM
  8. matty032's Avatar
    My battery life has went to h#ll since Pie. Going to try your fix.
    10-10-2018 11:05 AM
  9. Randy Spear's Avatar
    Battery life had been horrendous since updating to pie. Tried adaptive battery on and off and restricting the most offending apps. Nothing worked.
    Google support said I'd need to factory reset. Battery life has been better but not even close to what it was on oreo.
    I'm currently getting about 4 hours per charge.
    The October security patch hasn't helped btw.
    10-10-2018 09:38 PM
  10. 18t's Avatar
    Reading these negative comments make me glad I turned off update notifications when Pie initially hit. Hoping they get it figured out soon.
    10-11-2018 11:28 AM
  11. dyastrab's Avatar
    A week after I turned off adaptive battery, my battery life seems to be better.
    I also found out something weird about the Android Battery percentage indicator. If you fully shut down your phone and then turn it on a day or two later, the indicator will show you the estimated percentage of battery life remaining, not the actual charge left. I charged to 96% on Friday afternoon and then fully shut down my phone. I turned it on again Saturday night and the percentage was down to 65%. After using the phone for the next 3 hours, the percentage still showed 65%. I suspect if I had continued using it, the % wouldn't have changed until went below actual 65% of the charge.
    10-14-2018 10:40 AM
  1. How is the battery life on galaxy s8 with oreo?
    By Stan_oela in forum Android 8.0 Oreo
    Last Post: 09-26-2018, 12:06 PM
  2. Gear S3 battery life with AOD.
    By Android Central Question in forum Samsung Gear S3
    Last Post: 09-24-2018, 09:50 AM
  3. note 9 max battery life
    Last Post: 09-23-2018, 01:38 PM
  4. Battery life
    By Ziad17 in forum Samsung Galaxy Note 9
    Last Post: 09-22-2018, 09:05 AM
  5. Note9 battery
    By Ziad17 in forum Ask a Question
    Last Post: 09-22-2018, 08:43 AM
