OK, here is my setup: I have a Nexus 6 on Verizon. I used Google Voice for my voicemail (I disabled my Verizon voicemail), and I also use Hangouts for SMS. Along with that, I would get messages and calls that came in on Google Voice. Let's say the Google account is 12345@gmail.com, and the GV number is 123-456-7890.
I used that Google account to request Project Fi, and I received the invition not long after they started rolling out. I bought another Nexus 6 (used) to use on Project Fi, and I ordered the SIM only kit. After I received it, I turned my Google Voice account into Project Fi, transferring the number. So now, my 12345@gmail.com account is Project Fi, and my Fi number is 123-4560-7890. That part works fine.
I'm running into issues on my Verizon phone. First of all, transferring my GV account to Fi killed the voicemail for my Verizon line. What I ended up doing was to forward my Verizon number to my Fi number if it's busy or no answer. That works perfectly. It forwards after a few rings, and it goes right to voicemail. To the caller it is completely normal.
A bigger issue is that I cannot call my Fi number from my Verizon phone. It goes directly to voicemail. I place a call to 123-456-7890 from my Verizon phone, and the first thing I hear is "You have no new messages...". This means that I cannot call my Fi phone from my Verizon phone. I have the Project Fi app installed on my Verizon phone. I tried removing it, but it didn't make any difference. It still calls voicemail. I also tried canceling the call forwarding, but that didn't do anything either.
At this point, my Verizon line should not be connected to Google voicemail in any way. The calls I don't answer go to Google voicemail, but it is via call forwarding. Is this happening because of Hangouts? I can receive Project Fi calls on my Verizon phone via Hangouts, but for regular calling I use the built in phone dialer, not the Hangouts dialer. When I call the Fi number, I also use the built in phone dialer, not the Hangouts dialer.
Is the phone somehow automatically calling from my Fi number when I call the Fi number? I called my wife's phone to make sure all calls do not come from Fi, and they don't. Her Caller ID shows my Verizon number.
Any ideas? I suspect I would need to remove or at least disable my Fi account on Hangouts on my Verizon phone, but I do not want to do that.
