Save big + get 3 months free! Sign up for ExpressVPN today
  1. Shariar Mohammad's Avatar
    i was just on wifi and whatsapp and battery level was at 40% then it suddenly shuts off and i tried to power it on and also tried to take the battery off then place it and start but doest but as i connected the charger it showed 0% and charging... how could it drop from 40% to 0% just like that, and it isn't even the first time it happened, last time it happened the phone was at 20% and my messages come with a vibrate so as it vibrated it hit 15% then another msg and vibrate and it reached 10% then 5% then 4% and at tht point i shut down phone and charged it for 30 mins and it went up to 55% .... can anyone explain ? i have battery guru installed by the way and also 360 security and i have noticed it happens whenever there is a playstore update because the last time it happend and i restarted it had alottof updates...and this time too it had 2 updates that are samsung based apps
    Attached Thumbnails Why is my phone battery shutting down when I still have charge on it?-screenshot_2014-10-25-15-40-24.png
    10-25-2014 06:57 AM
  2. Golfdriver97's Avatar
    Could you post screenshots of your battery stats, please?
    10-25-2014 08:43 AM
  3. Shariar Mohammad's Avatar
    10-26-2014 10:41 AM
  4. Golfdriver97's Avatar
    That is really strange. Did the device get warm right before the shutdown?
    Sent from an AOSP M8
    10-27-2014 07:14 PM
  5. Shariar Mohammad's Avatar
    Not at all.. the screen timeout while i was chatting over whatsapp then it turned off and never turned back on
    11-01-2014 09:36 AM
  1. Is there a trick to getting the back off the Note 4?
    By Husker82 in forum Samsung Galaxy Note 4
    Last Post: 11-09-2014, 02:21 PM
  2. Weird issue happening to me
    By fadi dababneh1 in forum Samsung Galaxy S3 Mini
    Last Post: 11-06-2014, 10:53 PM
  3. Upgrade From S4 to Note 4
    By Kwame Carver in forum Samsung Galaxy Note 4
    Last Post: 10-30-2014, 11:25 PM
  4. 'Android Is Upgrading' After every reboot.
    By Sean2019 in forum Moto G
    Last Post: 10-27-2014, 09:00 AM
  5. Any way to change default dialer speed?
    By Timodeous in forum LG G3
    Last Post: 10-25-2014, 06:00 PM
