1. funz's Avatar
    My Nexus 5 has randomly been working up recently. Firstly, the battery display seems to be incorrect. It could be at 10% when I plug it in, and then display 100% after 5 minutes or so! Secondly, the entire phone completely dies without warning at random times, not coming back on until I charge it. This could be when the battery displays > 50%, and usually is.
    The phone turns off after 20 minutes or so even if I've charged it for 9 hours straight!
    I am currently running on Android 5.0 Lollipop. Anybody got any idea why this could be happening, and how I could go about fixing it?
    12-07-2014 10:00 AM
  2. B. Diddy's Avatar
    Welcome to Android Central! Offhand, I'd say the battery is either failing, or there's a loose connection somewhere.
    Charge up to 100%, then let it drain to 20-30% with normal usage, without charging in between. Then show us:
    1. The main Settings>Battery screen.
    2. The fullscreen battery graph screen (which shows Awake time and Cell Signal Strength).
    3. The Screen category (to see total Screen On time).
    4. The Cell Standby category, if present (to see Time Without Signal).
    http://forums.androidcentral.com/amb...d-central.html
    12-10-2014 03:25 AM
  3. funz's Avatar
    Thanks for the reply!
    Nexus 5: My battery is messed up and runs out absurdly fast (30 minutes???)-screenshot_2014-12-10-21-34-24.jpg
    Nexus 5: My battery is messed up and runs out absurdly fast (30 minutes???)-screenshot_2014-12-10-21-34-17.jpg
    It definitely seems like a fault in the battery, or a connection as you said.
    The problem has actually got significantly worse since I posted this thread, the phone will now turn off after 5-20 minutes of myself unplugging it. If I try and turn it back on, it will regularly just turn off instantly, but I could later in the day turn it on again after no charge, and have it easily stay on for another ten minutes or so, the whole time displaying ~ 90%!
    The screenshots I attached show battery usage, but the ~40% is displays is after about 20 seconds of me plugging it in after it "dying"!
    There is clearly something wrong with the battery itself.
    As for letting it drain, that's a no go! The phone will display upwards of 80%, and then turn off undoubtedly, refusing to come back on at most times.
    May I also say that when turning off, it does not display the usual "shutting down" screen, it simply blacks out instantly
    Any help is appreciated!!
    12-10-2014 04:41 PM
  4. B. Diddy's Avatar
    Did you buy your Nexus 5 from Google Play? If so, you might want to ask for a free replacement. I'm not sure if the program is still in effect, and if it's only for physical damage, but it's worth a try: http://forums.androidcentral.com/goo...-5-phones.html
    12-10-2014 05:40 PM
  1. Why does "Media" consume so much of my battery??
    By DLCPhototography in forum Verizon Samsung Galaxy Note 3
    Last Post: 05-11-2015, 04:41 PM
  2. Why are my video disappearing from my Galaxy S2 Skyrocket?
    By jdh1982 in forum General Help and How To
    Last Post: 12-10-2014, 03:27 AM
  3. S-voice vs ok google.. Which is better and why?
    By only foryou in forum Samsung Galaxy Note 4
    Last Post: 12-09-2014, 10:41 AM
  4. Trouble rooting *rips hair out*
    By Introvert4point0 in forum Samsung Galaxy S4 Rooting, ROMs & Hacks
    Last Post: 12-07-2014, 10:42 AM
  5. Why is my s4 discharging?
    By dxtructions in forum Samsung Galaxy S4
    Last Post: 12-07-2014, 10:11 AM
