Save big + get 3 months free! Sign up for ExpressVPN today
  1. Link169's Avatar
    my battery quickly drains with literal use. Plenty of people say "check battery settings to find whats killing it" usually says screen but i know my screen, at the lowest settings, should not drain 10% in 16 minutes with it being off in the 16 minutes. I recently got a new battery, reset plenty of times, gsam battery monitor says on average i get 7hrs a day and thats just music playing between classes and off during class, not off off just not used.
    any tips to find out the true source?
    Why is my Samsung Galaxy S4 battery draining so fast?-screenshot_2015-03-10-23-34-41.jpg
    Why is my Samsung Galaxy S4 battery draining so fast?-screenshot_2015-03-10-23-34-31.jpg
    here's screenshots of said performance
    03-10-2015 10:34 PM
  2. B. Diddy's Avatar
    Welcome to Android Central! It would be more helpful to see the stats after the battery has been used from a full 100% charge down to about 20-30%, so we get a better picture of the overall use.
    Charge up to 100%, then let it drain to 20-30% with normal usage, without charging in between. Then show us:
    1. The main Settings>Battery screen.
    2. The fullscreen battery graph screen (which shows Awake time and Cell Signal Strength).
    3. The Screen category (to see total Screen On time).
    4. The Cell Standby category, if present (to see Time Without Signal).
    03-11-2015 11:58 AM
  3. Link169's Avatar
    Here's the screen shot hope I did it correctly
    Attached Thumbnails Why is my Samsung Galaxy S4 battery draining so fast?-screenshot_2015-03-17-09-37-39.jpg
    03-17-2015 08:48 AM
  1. Bricked my S4 SGH-M919 :( Help
    By VeryHappySlug in forum Samsung Galaxy S4 Rooting, ROMs & Hacks
    Last Post: 03-17-2017, 01:35 PM
  2. Why won't my Samsung Galaxy S2 connect to any wifi?
    By AC Question in forum Samsung Galaxy S2
    Last Post: 03-10-2015, 10:36 PM
  3. Can i get 2 years out of my battery?
    Last Post: 03-10-2015, 10:33 PM
  4. Galaxy S5 - Android Lollipop (5.0) Keyboard Lag?
    Last Post: 03-10-2015, 09:13 PM
  5. Galaxy S5 Turbo Charging
    By Ian Allish in forum Samsung Galaxy S5
    Last Post: 03-10-2015, 07:34 PM
