1. wmcanally's Avatar
    This is the worst phone for battery life I've owned. I've dimed the display. Installed a battery saver. Moderate use I get 4 hours. Bought another new oem battery. Same results. Help
    06-14-2015 10:08 AM
  2. Miller6386's Avatar
    Can we get more info? How long have you had the phone? What version of Android? Did the problem just start?
    Sent from my ASUS Transformer Pad TF700T using Tapatalk
    06-14-2015 10:14 AM
  3. wmcanally's Avatar
    The phone is 6 months old. The verison is the lollipop. My wife's s5 battery has suffered since that update as well. Just not as bad as mine
    06-14-2015 10:33 AM
  4. Miller6386's Avatar
    With how major the lollipop update was it's best to backup all your data and do a factory reset. There are a lot of "cobwebs" left over from the update and the best way to clear them is to reset all data and system files. I know it sounds like a pain but it really goes rather well.
    OTA updates leave a lot to be desired as its just not the best way to update any software with major changes. That's why all other OS's always wipe all data and do a fresh install
    06-14-2015 10:40 AM
  5. wmcanally's Avatar
    I'll do that. Thank you very much
    06-14-2015 10:50 AM
  6. Miller6386's Avatar
    Let us know how it works. It will take a couple of days for the battery to settle in so if it's still a little rough right at first don't be alarmed.
    06-14-2015 11:16 AM
  1. How can I make my S5 battery last longer?
    By CourtW4 in forum Hardware Hideaway
    Last Post: 06-17-2015, 05:25 AM
  2. Galaxy Note 3 Used to Work on MHL Cable, But Not Any More. Why?
    By AC Question in forum Samsung Galaxy Note 3
    Last Post: 06-16-2015, 01:59 PM
  3. Samsung Note 4 vs S5
    By hermnagenda in forum Samsung Galaxy Note 4
    Last Post: 06-14-2015, 03:13 PM
  4. Where can I get rubber sticker for the home key of a Note 4 pad?
    By wmcanally in forum Samsung Galaxy Note 4
    Last Post: 06-14-2015, 11:39 AM
  5. Replies: 1
    Last Post: 06-14-2015, 10:05 AM
