1. hosamwanis's Avatar
    My Samsung Galaxy Tab 3 switch off when the battery indicator reach to 70%, When I connect the charger the battery indicator which appear during charging a switch off device indicate that there is more than half battery full. Is there any way to reset the battery?
    07-07-2015 06:25 AM
  2. itguyjax8430's Avatar
    Welcome to Android Central!
    Try giving this guide below a look and see if it helps.
    Pro tip: Revive your Samsung Galaxy Tab when the battery has completely drained - TechRepublic
    07-10-2015 12:06 PM
  1. Why isn't my S5 finding WiFi networks?
    Last Post: 07-10-2015, 12:03 PM
  2. Why won't my Moto E phone charge?
    By joehamster9999 in forum Moto E
    Last Post: 07-10-2015, 12:01 PM
  3. How do I disable shortcuts from the Security screen in 5.1?
    By AC Question in forum Legacy Android & Other OS's
    Last Post: 07-07-2015, 11:29 AM
  4. Can anyone access my Samsung S5 via data cable?
    By AC Question in forum Samsung Galaxy S5
    Last Post: 07-07-2015, 10:13 AM
  5. How do I change the password of a cm lock?
    Last Post: 07-07-2015, 08:33 AM
