Can I get some help with a battery issue?
amit ja
3
battery issue
I am using htc 820 dual sim phone its having big issue of battery . Draining even data off n screen is off when i find out that background aap running when screen is off its showing 70%, 75% used by androide os plz help me...plzz
Re: battery issue
70% to 75% of how much being used? 75% of 1% of battery use is great. 75% of 90% battery use is terrible.
The lines you're looking at are the percentages of the total amount used by each app, they're not the percentage of battery capacity being used.
Ashok Dharshan
