1. AC Question's Avatar
    when its on a charger it works perfect until i take it off the charger then i have like 1 min or so until it turns off and i have a hard time getting back on it...my storage is only half way full to and my battery is at 80%
    09-17-2015 09:12 AM
  2. belodion's Avatar
    A failing battery, perhaps?
    09-17-2015 09:35 AM
  3. androidcolors's Avatar
    maybe you battery is overheating. check it out the temperature of your phone either manually or using an application that gives you the exact temparature of the phone.
    After that, you can look for the apps (or maybe the hardware) that cause this shutting down.
    Good luck with this.
    09-20-2015 05:56 AM
  1. Why is my battery life draining so fast?
    By AC Question in forum Hardware Hideaway
    Last Post: 09-30-2015, 04:09 AM
  2. Replies: 1
    Last Post: 09-20-2015, 09:06 AM
  3. Replies: 1
    Last Post: 09-17-2015, 09:37 AM
  4. OneNote supports stylus on the GS6
    By galaxyfive in forum Samsung Galaxy S6
    Last Post: 09-17-2015, 08:54 AM
  5. Just updated my lg with lollipop and I can not put any thing on sd
    By jessie dotson in forum Legacy Android & Other OS's
    Last Post: 09-17-2015, 08:46 AM
