1. Reigns Forever's Avatar
    I recently bought a 12000mAh Samsung power bank. On it's back its written:
    Input: DC 5V/1A
    By which i understand that 1A means 1 ampere but i also brought a 2 ampere charger for it. I'm afraid something might go wrong so i wanted to ask if my power bank with 1A input would be safe to be charged by the 2A charger.
    Also would it charge twice as fast?
    09-23-2015 06:40 AM
  2. Teejai80's Avatar
    Hi and welcome to Android central.
    It will charge just fine. The amp rating is the max of current it can flow. You can going higher, however, you can't go lower. It will not charge faster, it will only draw the same amount of current.
    09-23-2015 06:41 AM
  3. Reigns Forever's Avatar
    Thanks
    As far as i understand 12000mAh means 12 amperes so no matter how high the charger my power bank will always charge at 1A?
    09-23-2015 06:45 AM
  4. Teejai80's Avatar
    Yeah it will only draw as much current (amps) as required.
    Sent from my XT1562 using Tapatalk
    09-25-2015 01:02 AM
  1. Why is my Samsung S6 edge battery draining so fast?
    Last Post: 10-01-2015, 12:50 PM
  2. S6 charged to 45% in 3 minutes?
    By bklyn2015 in forum Samsung Galaxy S6
    Last Post: 09-29-2015, 09:28 AM
  3. Why don't my bottom keys work?
    Last Post: 09-23-2015, 09:09 AM
  4. Replies: 0
    Last Post: 09-23-2015, 05:42 AM
  5. How do i turn my s6 off with no power button?
    Last Post: 09-23-2015, 04:54 AM
