Re: my battery is dead , so i cant charge my mobile in usual mobile charger
If the problem is with the battery on the phone then the only real option you have is to take it to a repair shop and have them look at it. Unless the battery can be removed then you can replace them pretty cheap online. Make sure that it isn't just the charger that has the problem, use another charger on the phone to determine it's the battery first.
